window adjustment
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by K5Buckeye, Nov 19, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    The driver's side window will not roll up completely. But b/4 I attempt to adjust it, how do I remove the door and window crank handle? Then, any advice on how to adjust the window? Thanks.
    1972 K5
    1991 Jimmy
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,957
    249
    Released from Pueblo, told I belong in Southpark
    window and door handle are easy. You can buy a tool for less than 10 bucks at napa or most other auto parts stores with a help section. The handles are held on by a c clip type thing that slides into grooves in the base of the handle. you can also do it with a couple screwdrivers but a lot easier with a tool. As far as adjusting the window I dont have a clue but am interested also. Half an answer is better than none at all. Good luck.
  3. K5Buckeye
    Mar 5, 2001
    75
    WA
    70jimmy, thanks for the tip. My pal had the tool to get to those c-clips. The brushes on the inner felt are impeding the glass. It's bent b/c I dented the top inner door (don't ask). I had it straightened and I ordered the window kit from LMC. Hope that does the trick.
    Later.
    1972 K5
    1991 Jimmy
