window adjustment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Buckeye, Nov 19, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    The driver's side window will not roll up completely. But b/4 I attempt to adjust it, how do I remove the door and window crank handle? Then, any advice on how to adjust the window? Thanks.
    1972 K5
    1991 Jimmy
  2. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    you need a special tool to remove the clip that holds the window crank on, and then just remove the trim screws.
    Good luck!
    The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants.
    --Thomas Jefferson
  3. K5Buckeye
    Mar 5, 2001
    75
    WA
    I got the window clip tool. How do I pop the clip off?
    Thanks.
    1972 K5
    1991 Jimmy
