window chanel molding seals installation
Discussion in 'The Body Shop' started by DukeBoy88, May 13, 2004.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I purchased replacement window chanel molding for my '85 and am wondering how they are installed. does the window glass have to be removed, or can it be slid down the track with the glass in place? thanks in advance.
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    On my rear window it just sort of snapped out and the new back in, we did it with the window in. /forums/images/graemlins/waytogo.gif
  3. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Sorry, I meant the drivers and passengers roll-down windows
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I did mine with the window in. Roll your windows all teh way down. Grab a small screwdriver (I wrapped the end of the screwdriver in tape so I wouldn't scratch anything) and pry the seal away just enough to get a grip with a set of pliers. Pull straight up and it should start to work itself out. Pull a small section at a time a little at a time unitl the seal pops out. Then put the new one in. I wanted the seals to slide in easy, so I put a thin coating of vaseline on the underside where the clips are. Snapped right in! /forums/images/graemlins/thumb.gif
    You can do the inner and outer seals this way.
  5. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    /forums/images/graemlins/doah.gif why didn't i think of that when doing mine /forums/images/graemlins/frown.gif
  6. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    that worked great, thanks alot. little bit of a fight to get them in but probobly easier then removing the window. /forums/images/graemlins/thumb.gif
  7. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
  8. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well, I know this is kicking the door WIDE OPEN here, but I keep a small jar of vaseline in my tool box. It's good for all kinds of stuff and cleans off stuff MUCH easier than grease. It's amazing what a little lube in the shop will do for you /forums/images/graemlins/whistling.gif
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Right on! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  10. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Vasoline will help ANYTHING slide right in the first time. /forums/images/graemlins/whistling.gif
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    ya just gotta be careful, 'cause Vaseline isn't good for, uhh, latex products. SOOOO, your latex products are gonna get little holes in them /forums/images/graemlins/doah.gif. And stuff can get in them /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif. More importantly, stuff can get OUT of them... /forums/images/graemlins/thinking.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  12. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ] /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    ya just gotta be careful, 'cause Vaseline isn't good for, uhh, latex products. SOOOO, your latex products are gonna get little holes in them . And stuff can get in them . More importantly, stuff can get OUT of them...
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    now I am curious on just how you acquired this knowledge?? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
