Window goes up, but not down
Discussion in 'The Garage' started by mudbog42, Feb 4, 2007.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Ok here's the issue, just replaced my tailgate and used the parts out of my old one because they worked just fine in the old tailgate, i put the motor and the regulator in and for some reason the motor will raise the regulator nice and fast but then when going down,:confused: it crawls and i must help it down.
    Now if I disconnect the cable from the motor, you can see and hear the motor spinning freely both ways:laugh: , hook it back up and the same problem.:mad:
    By the way this is all with the window disconnected and nothing attached to the regulator and for some reason it won't go down, this is becoming really irritating because I would like to be able to start using my tailgate again without becoming frustated everytime I need to use it:angry1:
    Any help would be greatly appreciated and thanks ahead of time:bow:
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Have you tried to spray some lube onto the mechanism? Stay away from lithium grease/lube. It dries out and becomes very sticky.
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    What kind of lube should I use? I did use the lithium grease, oops
