Window handle removal???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chalet 170, Jul 15, 2002.
  1. Chalet 170
    Chalet 170 Registered Member
    May 15, 2002
    19
    Bay Area, Ca
    I need to replace the window handle on my 76 K5. How do I get to the clip to remove?
    Doug
  2. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    screw driver, or needle nose, you just have to pull it out of there
  3. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    They make a special tool to remove the crank clip. It slips under the crank and pushes the clip out. They are VERY cheep and can be found at about any parts store.
  4. Chalet 170
    May 15, 2002
    19
    Bay Area, Ca
    thanks for the help.
  5. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    USE A PIECE OF STRING.
    Find the open end of the clip and use the string by placing over the clip and pulling on both ends at the same time.It will pop right out no special tool required. /forums/images/icons/wink.gif
