Window latch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, Feb 26, 2002.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    The little latch on the litlle window has become really loose, almost to the point where it doesn't want to hold the window shut. Has anybody ever had this problem or know how to tighten it down?
    Thanks!!
    88' K5 Silverado 9" Lift 38" Swamper TSL's
  2. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    You talking about the wing window lever on the door??
    <a target="_blank" href=http://www.geocities.com/custar/index.html>Your parents WANT you click here, NOW!!</a>
  3. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    There is a rubber washer on the outside of the latch (Between the rounded knob and the glass itself. I'll bet yours split (like mine) and fell off. I wrapped a few rubber bands around and around this knob, against the glass, the rubber bands compress etc when you close the latch inside, the more rubber bands, the tighter your window. It also helps when you're doing it to push the whole latch assembly outwards, thus making the gap on the outside for the rubber bands bigger...Try it, it works
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Go to your local auto parts store and you can buy a rebuild kit for that latch. It is called a wing window.
    1989 blazer, 383 stroker, D44 / 14FF, 4.56, locked, 35 BFG mud
    Scott
