Window Motor Repair
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Mar 22, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I just pulled then entire window assembly out of my passenger side, i undid the motor from the support arms so it was free, i pulled a black unit of the back of the motor which connects between the motor and the connecter switch. Only problem is when i did these two little metal stabilizers and springs came out, obviously that isnt supposed to happen but i cant get it put back together, the springs push the stablizers out to much so that i cant get them to fit around the end of the motor. any ideas or should i just go get another one? /forums/images/graemlins/k5.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I'm guessing the springs and armature brushes are what you are talking about. If I remember correctly, look inside the end of the motor housing you removed, there should be a plastic washer in the end of it, put the brushes and springs back in place and use the plastic washer to hold them in position, slide the end of the armature in place and it will push the plastic washer out of the way as the brushes slide into place on the armature. It's been a while since I did those but I'm pretty sure that will work.
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Bummer, I jusy sold a passenger side window motor on e-bay for $5.50. I would have sent it to you for shipping. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
