Window not working; window switch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Sep 12, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    A few weeks ago, I ran outside to rool up my windows in my 87 K5...I did it from the drivers seat using the drivers side switches. When I went to put up the passenger window, nothing happened...But I went to the passenger window and the window went up just fine with the passenger side swithc. Now the damn thing won't go down. When I hit the switch in the "down" direction there is nothing, no click, do drop in the voltmeter, nothing.But when I hit the switch in the up driection, the voltmeter drops just a hair and there is an audible click (the same click that you hear when you try to roll the windo up and its up all the way already). So does this mean that the "down side of the switch is fried or what? I know absolutely NOTHING about how power windows work. Any ideas gang...
    Thanks in advacne...
    Chris
  2. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    sounds like what happened on my moms car. her problem was the regulator
  3. NE79
    NE79 1/2 ton status
    Mar 10, 2000
    177
    Nebraska City, NE
    Same thing started to happen to mine, then one day it just gave up. All i did was disconnect the wires where they come into the door and clean the contacts. Works great and is faster now. I'm in the area now, so you can email me if that doesn't work.
  4. dyeager535
    26,980
    BTW, if you have to go this far, you can EASILY rebuild the switches provided they aren't broken. Typically the only thing that breaks are the connecting pins on the back, other than that, its a simple copper rocker switch inside, and the copper corrodes.
    Sandpaper and some corrosion resistant grease will make them good as new.
