window problems!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by militaryblazer, Nov 20, 2000.
  1. militaryblazer
    militaryblazer 1/2 ton status
    Nov 14, 2000
    235
    Azle, Tx
    I have an '86 Blazer with manual windows and sometimes the driver side window is real hard to roll up and down. And sometimes it will work real smooth. Does anybody know why this does this, and if a can of WD40 will fix it.
    <font color=orange>'86 Military Blazer with 4" Lift & 33" Tires</font color=orange>[​IMG]
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I had a hard to roll up window, and I replaced the window crank (the inside the door thing) with ones from a less-rusty truck that had been in a wreck. Kind of a lot of labor to take it all apart, but it fixed it.
    The roller run on two tracks that could be grimy and causing the problem. Or the gear thingy could need to be lubed. Hard to tell unless you take your door apart.
    -- Mike
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Check the track at the vent window. Sometimes mine slips out and it stops moving.
    90K5
  4. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    Take the door panel off and see if the track on the bottom of the glass is rotted. If so it will need replaced.If not, soak it and the regulator with white lithium grease and spray the rubber channels with WD40.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
