Window Regulators shot.
Discussion in 'The Garage' started by k5guyva, Nov 17, 2003.
  1. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    1982 Blazer with the typical crappy manual windows. I got the door panel and window crank off. How do I replace the window regulator without removing (or breaking) the window? I see about 5 bolts holding it in. Is it a simple prop up the window and unbolt it? I never did this before on the truck, so some help is appreciated.
    /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    figure out how the window is attached to the regulator, probably bolts or rivets, remove them, either remove, or support the window, then remove the regulator...reverse procedure..
  3. the hulk
    the hulk Registered Member
    Feb 9, 2003
    40
    phx az
    you need to take the vent window out with the vent window out you can side the door glass forward and off the track the vents window take two mins to get out .
