window rubber
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Jul 12, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    the rubber around my windows are dry rotted out and needs replacing. this is both front windows and the rear window. how do i do this? of should i have it done? i have power windows.
    '85 K5: BIG BAD AND MEAN
  2. 1TUFF89
    1TUFF89 1/2 ton status
    Apr 6, 2000
    109
    West Point, Virginia
    Do you have a LMC catalog? They sell the window trimming and you should be able to do it yourself. You can go to their website lmctruck.com and order a catalog for your blazer year. If you already have the rubber trim I wouldn't think it would be that difficult. Just be sure to use plenty adhesive.
    Chevy's RULE!
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Just roll your window all the way down, and the weather stripping has clips that will pop off. Kind of gently pry it off with a flat head screwdriver and the new set will pop into place.
    89 K5 Silverado
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    But how easy is it to install the new ones? There doesn't seem to be much clearance in there to ensure that it clips in properly....
  5. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I have power windows and replaced the rubbers on my driver and passanger side, the only problem I had was is it would move because it had no lubrication. I used water and soap and it went on pretty easy...wasn't the easiest thing i ever did though
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
