Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Sep 15, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    My driver's side power window is messing up. It usually works well and is fairly fast, but today, I tried to roll it up and it went up about 4" and stopped. So I rolled it back down, same thing. Now it won't go up past 1/4" or so, is it a bad motor, or binding in the track? Anything I should look for when I pull the door panel?
    AW
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    That's pretty much your two choices....lube it up well and see if that helps.....then replace the motor. Every one whines about the "sorry" window motors, but most are 15 to 20 years old. Put a new one in and get another 10-15 years of good service.
