Windows XP Pro help...FAST!!
Discussion in 'The Lounge' started by big pappa b, Oct 17, 2005.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Like the genius I am, I took all my program CD's out of the original package and put them in a zippered case. My hard drive crashed and I'm in the middle of installing windows again and can't find my damn registration key
    HELP!
    anyone
    just PM me if you can help
    thanks
  2. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    your kinda screwed. if you are using windows XP pro. you need the code for that CD or not everything will load. i had the same problem. And used another code. Did not work. Had to call Windows Support. :eek1:
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Well, I found one that works. Hopefuuly I can find my original one later if this one gives me any problems
  4. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    good luck. post up if you have any other probs.
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If you can still boot the old drive, even barely, there's a script you can run against your that windoze installation to find out what the key is. You can then run the same thing on your new installation and even change the key.
    Also, in the last few years, manufacturers have been putting the key on a sticker somewhere on the machine itself. If it's a laptop, flip it over and look, if it's a desktop, look on the back, top, or side of the chassis.
  6. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    you should be able to call micrsoft and they should give you a replacement
