Windshield caps?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Dieselmh, Sep 5, 2001.
  1. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    How does everyone cap off the holes in the top of the windshield when going topless? Did you cut a piece of metal to fit and bolt it down, or did you buy a better looking piece? I don't want my windshield frame to rust out, just looking for ideas. Thanks.
    Diesel
    Everything's bigger in Texas!
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    What holes are you talking about?
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. Dieselmh
    910
    Texas
    I'm talking about the holes at the very top of the windshield frame on the corners. I have bolt holes all the way across the top of the windshield frame, and on both corners, there is a triangular shaped hole. Does someone make caps for these, or do I have to make my own?
    Diesel
  4. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Your weather stripping should cover those holes. the rubber should go up along the windshield frame and forms a triangle at the top. It is fastened at the top by three bolts. the rubber is moulded over a metal plate, which covers those holes.Look at the holes and you should see some metal tabs with threads in them for the bolts. Did you have a top on your truck?
    [image]http://albums.photopoint.com/j/View?u=1328774&a=9975627&p=33244094[/image]
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    There are factory gaskets that're supposed to screw onto the frame at those holes. They're part of the door gasket set. They are triangular-shaped and made of rubber.
  6. Dieselmh
    910
    Texas
    I have the hard top to my truck, but the guy had lost all of the hardware. I guess I'll have to make some metal caps and cut a piece of rubber to fit. Thanks for the help guys.
    Diesel
  7. 1HIHUM
    Jun 28, 2000
    366
    Fremont, CA
    Just buy new weather stripping for the doors. The're part of the weather stripping. No need to make anything!
