Windshield removal tips?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BKinzey, Aug 24, 2006.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    It's already cracked but I'd rather not just bash it out.
    I've seen something looking like a garrotte (sp?) being sold. Basically a piece of piano wire between two dowel rods. Easy enough to make but how do you get it under the rubber seal in the first place? I'd like to use the rubber again if I could and anything I think of would tear up at least part of it:rolleyes:
    Should have paid attention when that guy was replacing one in about 15 minutes:doah:
    Advise on putting in a new one as well:D:D
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If its already cracked , just remove the lockstrip , and push it out . Use your feet is easiest . I took mine out by hand pushing .
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    x2...
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I removed the lockstrip, used soapy water and worked my way around with three flexable plastic butter knives, worked like a champ. Work your way from a top corner down about half way and then across the top and down the other edge and then the bottom lip comes out pretty easy.
  5. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I'll give it a try. This has a sealant in there as well so could be tough going. I've pulled the seats so using my feet won't work as well:doah:
    I'm going for the rubber seal as it's in very good shape and the dashboard frame to replace the cut up Mil M1009. Started another thread on removing the dash frame which could be a job in itself!:rolleyes:
  6. BowtieBlazer
    Jul 15, 2001
    2,462
    better you than me
  7. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Waaaaaaaaaa:yikes: Don't scare me! I'm timid enough as it is:o
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    after looking at my last CUCV parts truck it actually looked less intimidating than ever before
