windshield wiper Q
Discussion in 'The Garage' started by spincast375, Dec 17, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    when im using the wipers, they turn off in a vertical position.
    how do i correct this
    is it the dash switch or the motor itself? else?
    tks
    jw
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    mine does that, wiper motor is bad or just needs some attention. Put a new ground wire on the motor to the chassis and try again. Whats happening is the metal contact inside the motor fell off of the roller/ (circle spinner) and it wont make 12 volt contact if the switch is off. The factory splices the hot (12v) and runs it to the plastic roller and to the motor on the bottom. I used lots of wd40, ran new wires from the switch to the motor and disconnected the windshield pisser as it started to leak and rust out the motor. if the slow speed and the fast speed work and you still have the problem then its the switch. The off and the low speed use the same hot wire that runs off of the roller inside.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    try cleaning the connectors that go to the wiper motor, sometimes cause funky problems. I have intermittent problems with mine, I get pissed, punch the motor, and it works fine. Go figure.
