windshield wiper question
Discussion in 'The Garage' started by k5 krawler 50, Feb 10, 2005.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Everytime i turn on my wind shield wipers, the cleaning fluid comes squirting out of the little hoses, any body have this problem before, and how do i make it stop?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    The factory washer pump is run off an eccentric on the wiper motor. There's a relay that engages the pump when the switch is closed. Disconnect the wire going to the pump connected you your wiper motor and see if the pump stops. If so then you have a short in the line or a bad washer switch. If it doesn't stop then the relay is stuck on.
  3. Can Can
    15,555
    149
    Cochrane, Alberta, Canada
    Is the wiper control for an 82 located on the lower dash to the left of the steering wheel?
  4. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    thanks for the help, i am going to check it out tomorrow. the switch is on the lower dash panel.
