Windshield Wiper Switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by redneckdude, Feb 9, 2005.
  1. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Anyone ever had one go out? Mine doesn't work at all anymore, and started to smoke once...lol...pulled the fuse and all was well after that, but one day it just got hard to turn on and i gave it a little more force and heard some pop so im pretty sure the mechanism inside the column is shot...It isn't that hard to pull the steerin wheel off an change it, is it? Thats one of the few things i have yet to take apart on this truck. Also, what is the name of the actual part that the lever feeds into inside the column?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if no shorted wires anywhere then yeah most likely bad switch unit yep, techncally known as combo switch assembly, 84-up
    good luck
  3. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    to get into the column you will need a special tool, go to the parts store and tell them what your doing, if theyre good they will know
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    it hooks into the white turn signal switch in the column and has the dimmer switch rod hooked to it...
    it CAN be replaced without special tools but the lockplate and retainer are a bear without a lockplate depressor tool (wow, deja vu). http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10306&group_ID=1243&store=snapon-store&dir=catalog
    you can get the wheel off the splines with either a puller or loosen the nut till its at the end of the threads and have someone shock it with a softface hammer while you pull on the wheel...
