windshield wiper washer
Discussion in 'The Garage' started by st08x, Mar 26, 2003.
  1. st08x
    st08x Registered Member
    Oct 17, 2002
    84
    Texas
    i have an 82 k5 and has long has i've had it, the windshield washer fluid has never sprayed out, i guess its the motor, but which way would you push the switch to make it spray if it did work, on mine u can either push it to the left and the wipers will move once and u can push it in and it will move once, which direction controls the fluid???
    My k5
  2. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    When you push the button, hold it in and see if you can hear the pump going. The switch has a detent that when you push the button, it stays in the first, or low, position.
    Diesel /forums/images/graemlins/burb.gif
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Do you have the switch on the dash or on the column?
  4. st08x
    Oct 17, 2002
    84
    Texas
    its on the dash, no i don't hear any kind of noise or anything, i guess its a bad pump...
    My k5
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    That style uses the pump that is mounted to the wiper motor. Mine will only work if I prime it. You should be able to get a universal washer pump or a rebuild kit at Autozone if you want to bypass it.
    When you push the switch in it is supposed to engage the pump.
