Windshield wiper weirdness...
Discussion in 'The Garage' started by AJMBLAZER, Feb 20, 2007.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    The day I bought Big Ugly (back in October of last year) the wipers seemed to work fine. Being a CUCV it only has the three basic settings - off, usually too fast, and better be a downpour. I swear that first day the wipers would return to the down position whenever I turned the switch off. Ever since then they immediately stop when I turn them off, no matter where on the windshield they are. No biggie as I just wait until they're almost down and click them off. Is this normal or a usual issue?
    Now all of a sudden my washers are giving me issues. It's been so cold I haven't used them frequently but have a few times a week or so. The truck sat over the weekend and then yesterday on the drive to work the washers wouldn't spray. I was busy so I just sorta ignored it until today. Wouldn't work on the trip to or from work but when I turned the truck off, popped the hood, and then watched while I stood there they suddenly sprayed intermittently as the wipers moved...and didn't stop until I manually turned them off. Now they seem to work.
    Seems like you never pay attention to stuff until it does something weird. Is this normal?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Neither issue is normal. The wipers should return to rest at the bottom of the windshield and the washer fluid should only be sprayed while you hold the switch.
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Can't help you, but my CUCV was stuck to where the spritzers would always run whenever the wipers ran. Annoying. Eventually it fixed itself. My K5 has been in that mode before too. :rolleyes: Oh, and the fast wiper mode on the CUCV only works half the time too.
    I don't know what to blame this on. Switch, wiring connections, wiper motor, spritzer pump/motor?
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    They kick on by themselves in my K10 sometimes
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Don't feel pregnant.. my K5 does he same thing. It has since I bought it. I've been too busy focusing on the build up parts to mess with it. But I'll get around to finding the cause some year.. or another. It's probably something simple.
  6. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    This is such a common problem with GM's its rediculous. Its all due to that wiper/washer/weird mechanical combo piece bolted to the firewall. I ended up disabling the pump in that hunk of crap and wired in an electric washer pump that works with the stock switch. I can post pics if you would like them. PM me and let me know!
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    My wipers do that too. Its wicked annoying! They did it since I got my truck then they worked as their supposed to for like a year, and ever since the last time I dug into the dash they now do it again.
  8. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    There is a set of points in the wiper motor mounted on the firewall this is what makes them stop at the bottom. There is also a cam on one of the gears which makes the points open and close. IIRC. The points break the power to the wiper motor. All of this is under the black cover on the wiper motor.
    Make sure the contacts of the points are clean.
    Hope this helps,
    Mike
  9. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    i thought i was the only one with this....no idea how to fix it thow
  10. dyeager535
    26,980
    This is only a problem on the "early" rigs. Somewhere around '84-85 they put the pump in the washer bottle. Problem solved.
    Good upgrade.
  11. 454k30
    Sep 13, 2004
    1,613
    California, MD
    ya thats basically what I did. not in the bottle but mounted to the fender wall. works a lot better.
  12. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Mine should be a '86 but there's no pump in the bottle.
    Gotta love it...
  13. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Mine's an 85 and has the pump in the bottle :confused:
  14. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Seems to work about the same as always today...sleeping dogs lay...
    Who knows, maybe GM used up old parts when they built the CUCV's.
  15. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I wanna know how you have too fast of wipers, if its misting mine better be on low, none of this intermittent crap, if its a light rain they better be on high, and if its a moderate to heavy rain, find an overpass, put on a pair of goggles, spray rain-x all over them, and stick your head out the window.
  16. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    On the highest setting mine seem to just whumpwhumpwhumpwhump across the windshield. I guess years of driving 1990's and newer vehicles have spoiled me a bit.
    Also consider right now it's winter here. You get crap thrown on your windshield every day that is indeed wet but is also not coming at you like rain. It'd be great to have the first intermittent setting and just have them come on every 30 seconds or so...instead of smearing everything on the windshield continuously.
  17. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine does the same thing....
    Never bothered me in SoCal but now that I am in MS I really need to fix it.
