Windshield wipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Oct 6, 2002.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    the windshield wipers one my 89' Jimmy /forums/images/graemlins/k5.gif only run at one speed and i need them to do all speeds to pass state insp. any ideas on what the problem is and how to fix it?
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i'd check around, but down here (texas), they just have to work period. i'd call somewhere else and ask them. however, i'm sure you want to fix them. i'd start with the switch.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The windshield wipers with delay and multiple speeds have a relay box that handles everything but the full speed, check it if it's defective replace it.
    I will try and find out in your truck where it would be and get back to you on this. I hope I can find it in the haynes, that's all I have.
    IceMan
  4. dyeager535
    26,980
    It's likely going to be right around the ignition switch at the base of the column. Thats where mine is, and I've got the same wiring for the wipers that the truck in question does.
    Not sure how many times GM hanged the design, (I've seen smaller ones) my "delay box" is about 2.5"w X 4"l, with aluminum "fins" (heatsink) on one side. Wiring plug on both ends of the box. Both have locking connectors, so if you find it, don't break it : )
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    /forums/images/graemlins/smile.gif
    Thanks dorian, I have soeme sticky fingers, at least someone got what I was talking about.
    IceMan
