windshields
Discussion in 'The Garage' started by alf4444, May 17, 2006.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Anyone ever replaced one theirselves? any tips tricks problems??
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Not too difficult to do yourself, much easier with a helper. Mever let metal contact the windshield and you should be ok. I put a crack right down the middle of the last windshield I installed. The flatblade screwdriver slipped off the putty knife and chip... it soon cracked straight down the middle. Good luck. More tips- use lots of soap and water to help the gasket slip over frame/windshield.
  3. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I recently installed rear sliding windows in place of my solid ones. Even with a helper, it was definaly fustrating. I could only imagine how much more difficult a windshield would be. I will tell you I don't think that I want to find out and I will be calling the glass dude for that.
  4. dyeager535
    26,980
    If you've already got the glass, go for it.
    If you are trying to save $20-40 by getting glass yourself and installing it, call a pro. :)
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I did mine myself,,,very easy, the old one being all cracked and whatever, i simply removed the zipper strip, and sat in the drivers seat with the feet on the windshield, and just pushed out the old one. Yeah it broke even more, but why care, just have a friend with you on the outside to help with catching the old one, and make sure to wear gloves. Some very small pieces fell on the dashboard, but no biggie,,,
    Cleaned everything up, put the gasket around the frame of the truck, dropped in the windshield, used some soapy water solution, sprayed all around, and worked the rest of the gasket into place,,
    The fun part is reinstalling the little rubber zipper piece.:D
