windstar fans specs?
Discussion in 'The Garage' started by yunit, Jun 2, 2004.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    What are the dimensions of the windstar fans?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Hold tight for a sec......
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    30" by 18". Covers my whole radiator but about an 1" on the bottom. I worked my BBC in the rocks hard a few weeks ago with no heating problems at all. I say do it. /forums/images/graemlins/thumb.gif
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    How thick are they?
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I just finished a 4 core big block radiator and windstar fan swap. I'm loving it. I had a flex fan and about 1/8th of a fan shroud before. In traffic with the summer heat of Yuma, forget it. The temp would climb like it was nothing. But know, I went and did some wheeling on sunday. It never went above 200. With the big radiator, there is about an inch and a half on the bottom the fan doesn't cover. But other than that It looks almost factory. I can post some pics if you'd like.
  6. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Are you guys just running them on a toggle? How are you doing it?
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Pics please and more information on making it work. /forums/images/graemlins/waytogo.gif
  8. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    pete i am runing 1 with a big block rad 4 core and it works well
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I got these awhile ago and am having to trim the shroud quite a bit to get them to fit right on my '72. Also trying to mount them so they will not fall off when wheeling is an obsticle I under estimated. /forums/images/graemlins/hack.gif
  10. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    What relay/thermostat kit are you using with them Matt?
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I currently have two 30 amp relays in parallel running both fans at the same. I plan on switching to a constant duty selenoid when I get around to it. I've thought about running the small fan all the time and then hooking the big fan to the fuel injection control to turn on at temperature. Maybe I'll just hook both fans to the computer and use the switch for rock lights or something.
    Hmmmm...
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'd mount them so that the gap is at the top. There is always water to be cooled at the bottom of the radiator. If your coolant gets a little low, then the upper section of the radiator is empty anyway. /forums/images/graemlins/eek.gif The engine is also pulling coolant from the bottom of the radiator. So cool that section the most and don't worry so much about the top. /forums/images/graemlins/thumb.gif
  13. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Personally I'd mount it with the gap at the bottom. Hot coolant enters at the top, exactally where I'd like the most airflow to extract as much heat as possible.
    James
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It doesnt fit down as the clearance is not there due to the narrowing.
    But thanks, I had no idea how a radiator worked. /forums/images/graemlins/rolleyes.gif
  15. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    Working on it... /forums/images/graemlins/thumb.gif
  16. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just as I suspected! Being from Idaho and all... /forums/images/graemlins/wink.gif
  17. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Anyone know how thick these fans are? I have a vehicle with only about 4" between the radiator and the water pump. Wondering if this might be an option... /forums/images/graemlins/thinking.gif
  18. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I don't know anything about the windstar fans, but I am running a electric unit off of a 3.8 V6 Taurus mounted to a piece of sheetmetal, covers the whole radiator like that and cools like a banshee... It was 20 bucks at the bone yard, is wired thru 2 relays (1 for each speed) and a manual toggle switch. I have yet to get my truck to heat up running this setup...except when I forget to turn it on!
  19. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
