Wing window replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blaster, Aug 17, 2002.
  1. blaster
    blaster Registered Member
    Aug 12, 2002
    10
    Ames, Iowa
    Can anyone help me with the wing window replacement?
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    If your talking about the vent window in the doors- here goes
    Take out the 4 ? screws. don't forget the 1 on top of the door.......take off your door panel.... 3 bigger bolts holding the vent window through the door .....roll down the main window. Pull like H*ll to get the frame to pop free.... pull towards the front of the cab, and also try to turn the frame....easiest to turn it in towards you. Pull Pull Pull and it will pop free.
    An easier way is to pop the main window off track, and release the bolts that hold the main window frame first.... then try to take out the vent window.
    Hope this helps
    also- there is a very itemized instruction in the Hayes manual for my year, you might want to pick up one of those if you don't have one.
    Brandy
