Wing window seal thingy wtf it is...
Discussion in 'Parts & Trucks Wanted' started by ChevyCaGal, Feb 5, 2003.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I need a seal, I suppose that is what it is called for a wing window in the door (not the slider wing on the hard top). It's the little seal that goes around the window itself in the moving part when you open it. Hope that makes sense? Anyhow if someone has one please let me know. I went to the dealer and they want me to buy a whole new frame for like $145 bucks... kinda expensive for a piece of rubber... /forums/images/graemlins/tongue.gif
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    The Glass Shop that replaced mine just glue it in on mine. I didn't want to pay that much eather....
  3. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I tried glue but it leaks after a while because it dries out. I tried getting some thin rubber hoses and cutting them flat to size but I cannot find anything that works to make it fit just right. Who knew a little stupid thing like this would be so annoying!
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Have you tried LMC?
  5. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    They don't sell just that little piece of rubber, they want me to buy a whole wing window frame assembly... /forums/images/graemlins/tongue.gif
  6. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    lmc calls them vent glass seal.they are 19.95 a piece for 81-91. /forums/images/graemlins/thumb.gif it's a 2 piece for the 73-80 rear is 16.95 front is 19.95 hope this helps you
  7. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Hmmm I'll go without. It's a piece of thin rubber about 16" long and 3/8" wide. I just haven't been able to find anything that is thin enough to use but I will keep trying. But I sure won't pay $20 for that, what a rip off and huge mark up... thanks for looking though, I do appreciate it... /forums/images/graemlins/smile.gif
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Try this - clean the rubber real good with bug and tar remover or something like that. Get one a caulking gun and a tube of black silicone for it. Coat the edge of the window with petroleum jelly then use the silicone to build u the seal where the window closes. Close the window onto the silicone when it's still wet, smooth out the all the silicone to make it look nice, then wait for it to dry After it dries open up the window and wipe all of the petroleum jelly off of it. I did this on the safari windows on a freind's VW van and it worked great. /forums/images/graemlins/thumb.gif</font color>
  9. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    any time /forums/images/graemlins/thumb.gif
  10. Big10
    Big10 Registered Member
    Aug 30, 2002
    84
    Georgia
    shaggy, your just to dam handy for your own good /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    good idea
  11. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    If you need vent window weather stripping, I'm selling a brand new set.
    It sounds like you are asking for the rubber that actually holds the vent window glass securely within its frame?
    I'd have to try using a Bicycle inner tube for that...and of course some Ultra Black Silicone to make darn sure that it's weather tight.
    Good Luck with it; I'm sure you'll think of something to use that'll work out just fine.
  12. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yup, just the rubber strip that holds the window in the frame, nothing else. I tried to silicone thing and it didn't work so hot. Maybe my second attempt will turn out better...
