winshield washer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Oct 27, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    The other day the window was a little dirty, so I turned on the washer thing. Well, every time I just turn the wipers on now, it starts squirting the windshield washing fluid out. Is there a way to turn it off, or is something wrong? Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    I had the same thing on another car . The gear that runs those could be stripped . There is acog on the gear that disengages the gear so it doesn't work . I think you can get aprts to rebuild your pump . If not replace it . Until that time either take the washer pump off or pull the hose on the resovoir .
  3. Md mudder
    Md mudder 1/2 ton status
    Sep 29, 2000
    139
    same thing happened to my 84 p/u I worked the switch back and forth quickly a dozen times and it stopped for awhile but eventually had to replace the whole switch.the contacts inside are worn.
    <font color=green>Ryan</font color=green>
