Winshield wipers probelms
Discussion in 'The Garage' started by TexasBlazerBoy, Mar 27, 2007.
  1. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Windshield wiper problems
    They will work properly for a while, then they will quit. Then I will turn them on again and they will work....for a little while and then quit:doah:
    New wiper motor needed?
  2. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Does it do this?
    Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off.On.Off?
    Funny, I've been having the same problem. But sometimes mine goes
    Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On..........Off..........On.
    Let me know when you get it figured out.:D
    Seriously, sounds like a loose wire to me or maybe relay.
  3. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    Mine do the same thing. Its like the motor just slowly runs out of power then they stop. I can turn the switch off then back on and they will start moving again. Mine also only works on High. No Intermittent,Low, or Washer fluid. Only thing that really gets me by is a little rain-x on the windshield but if it comes a flood I can't see nothin.
  4. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    tHANKSSMARTAS*S:wink1:
  5. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Sounds like its time for a new wiper motor. The armeture is probably heating up and seizing, then you turn off the power and it cools then does it again. Thats the same reason why power window motors burn out. I got some more life out of mine by pulling everything apart and cleaning and lubing it. Then I was good to go for about one more year
    ~Brian
  6. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Thank you
