winter approaching FI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Oct 29, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Winter approaching...and ive been giving the switch from carb to fi some serious thought.
    How practical of a switch is this? Even just to a stock tbi, mabye find someone who wants to trade. What all will have to come off my truck for it to work?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For the swap you will need:
    Complete TBI setup,ECM all sensors and wireing harness.
    TBI distributor. your HEI dist wont work with TBI
    TBI Manifold or adapter plate.
    TBI fuel pump
    Plumb fuel return line back to fuel tank.
    You can get all this stuff off a donor vehicle or buy complete aftermarket kits.
    http://www.turbocity.com
    http://www.howell-efi.com
    These guys sell complete bolt on kits minus the dist for around $1200
  3. tecton
    Dec 1, 2002
    1,553
    WV
    you could just buy a TBI truck for that
    1200$!!! damn
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it ain't cheap! It would be way cheaper to just fix your carb so that the choke works properly. /forums/images/graemlins/wink.gif
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    yea, but then you have to deal with its issues: hacked harness, bad sensors, nasty TBI, etc etc. Going new is nice. Going used is kewl too if you have the time to sort thru the harness and sensors.
    I have gone both ways. I installed a new EFI system on my BBC, and since then replaced the BBC with a donor '91 350. I had ALL the parts required, and a pretty good harness to work with. It still took me an entire day to sort thru the harness, and eliminate what I didn't need - and I had pretty intimate knowledge of the ECM's harness prior to getting into it.
    If you get into the project, be sure to check my site for info on the ECM harness! /forums/images/graemlins/grin.gif
    -Dan
  6. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    you could just buy the Holley complete setup from summit or jegs.Iknow someone who has this on a 305 HO motor with a cam and mild head work and loves it.Im pretty sure he said it came with everything u need!!! /forums/images/graemlins/k5.gif
