winter clean up sale
Discussion in 'Pacific Region' started by 55Willy, Jan 2, 2007.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I spent 8 hours cleaning out a 12 x 36 bay making room for my 68 burb.
    Lee i think i got you everything you needed right, well minus your cherry picker but thats there for ya.
    33 x 14.5 x 15 swamper ssr's 75% tread, 2 chewed beads, they do hold air fine with no leaks all 4 $250 (thats each new :eek1: )
    31 gallon tbi gas tank with pump and sending unit, fuel line and return with stock braided lines that join at the shackle area and go up to the TBi unit, TBI unit is not included nor is the intake $75
    tbi $100- pending
    2wd th350 $50 not sure of condition so priced as a core
    2wd th400 $150 works fine got in a traded for a 4wd conversion
    12 bolt out of my 68 burb 6 lug $100
    465 32 spline had a 208 behind it no adapter or bell$75
    64" leaf packs out of a 95 blazer $100
    small block flex plates, 1-350 and 2-383/400(one used one new)
    open for trades as well
  2. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Ever get a chance to look at the Jeep front end? Now I'm kind of curious what is causing the grief. Just curious.
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    just drove it and it was fine again around the block around campus. it did how ever start to shimmy once i came over the railroad tracks. on another board they said to check the shocks. with them upside down there maybe no damping.
    i wish i had a way to get a good visual of the front as it does it o see what is infact moving or not moving.
  4. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I wonder if getting someone in front of you with a video camera would work? It would have to be a bumpy road because the only time I saw it start to oscilate was when cornering hard so the suspension was under compression going over a bump.
  5. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    You still got 'em and where are these located?
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    still got them, they are in corvallis oregon
  7. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    Sent you a PM.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    tag you're it, LMAO
  9. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    Right back at ya'! :D
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    send 2 more shwoing the worst of the cut beads, it is hard to see but it on the inside of the tire only and not where the rim seals up to.
