Winter-izing
Discussion in 'The Lounge' started by kyser_soze, Oct 30, 2005.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Changed the thermostat in my truck, wipers and waterproofed my boots. It's not cold yet here but will been soon.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Bought an extension cord to run my block heater off of the church I park next to at school. :D
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    need to swap the stap too, my 180 from last year is stickin.
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Gotta change the rear main seals, get some ice tires, add some coolant (its too thin right now) put some thin synthetic oil in, and get crackin on tuning the chip up so she'll start when it gets real cold out.
    Already replaced the block heater thermostat and heater core, she should be good to go pretty quick :)
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    What a coincidence, the new extension cord was all i bought this year too. :D
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I put on long pants...But only cause I'm gettin old...:p:
  7. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I'm afraid to put good antifreeze in anything until the last possible minute. Otherwise the radiator goes bad, a hose blows, or something makes me lose all the new coolant I just bought.
  8. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    me too!
    I SWEAR new prestone has a "leak seeking" agent that causes leaks!. :hack: .every time I've flushed out a radiator,and put in new (and expensive) prestone,it leaks sure as S*** somewhere the next day,either at the hose clamps,radiator spings a leak,or the friggin water pump starts dripping out of the "pee" hole!.. :mad: ..
    I got to the point where I just used my old anti-freeze over when I do a motor swap,(i filter it out by straining it thru an old woolen sock!)--and add a bottle of that "booster" or "water pump lube" stuff in instead..and I add used 50/50 antifreeze I can get free from the junkyards or my friends shop to "top off" if I'm a little low...so far,none on my trucks have leaked a drop!--I just make sure its safe for -10 degrees,and say screw it..I only drive them 2000 miles a year,sometimes even less..this year,a LOT less,thanks to the fuel prices.. :( :crazy:
  9. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I found 2 gloves that match, but both are left hand.
  10. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    well I have 2 right hand'eds that nead a match :thinking:
  11. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Put a coat of wax on it, too, so the snow/ice slides off easier.
  12. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    Hey, I forgot about that one!
