**** wiper blades
Discussion in 'The Garage' started by cbbr, Oct 16, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    How do you get them off? THere does not appear to be a retaining ring or any logical way?
  2. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    Crap I just did this. After forcefully prying off the first one I took a better look. There was a tension spring on mine. Flipped the wiper around bent backwards and wiper lifted off.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    there is usually some type of tab that you need to push down or pull up on inside the body of the wiper right by the pin. look at the new ones to see how they attach, that should help.
  4. cbbr
    Jul 17, 2004
    14,681
    I pulled, pushed and prodded. And then took a big screwdriver and just popped them off....
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    The OE metal style you need to bend slightly backward to get the tension off the spring. Then gently rock it off the stud.
    The newer design (Anco, Trico, etc...), you need a small screwdriver to push the small plastic retaining tab away from the stud. If you use the access hole ontop of the wiper, you will be pressing down.
    I see you got it off, just wanted to say something for the others...
  6. cbbr
    Jul 17, 2004
    14,681
    Good advice. Mine were OE. You can push a big flat blade in and they just pop off. I was a bit frustrated.
