Wiper delay setup for non-delay factory setup?
Discussion in 'The Garage' started by mouse, Apr 21, 2004.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Is there an easy way to convert the non-delay wipers to a delay setup. After using delay wipers for years the non-stop factory wipers on my Blazer are annoying - especially when its hardly raining.
    /forums/images/graemlins/ears.gif
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Now , I am not sure if this will apply to a 75 truck
    I have in the past had my delay wipers screw up /forums/images/graemlins/angryfire.gif and was able to un-plug the box under the dash , and simply plug the harness together , resulting in non delay wipers
    So , I now wonder if you can just plug the delay box into a non- delay system and have it work /forums/images/graemlins/thinking.gif
    You would also have to use a delay switch
    BTW this was on a 85 1/2 ton
    I am not sure if it will work for your application /forums/images/graemlins/confused.gif
    Mabey someone else will know better /forums/images/graemlins/thumb.gif
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You'll need the switch and the control box.............think LMC has them both. Not sure if it's a plug and play but hopefully someone else will chime in who's done it.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    TTT................that is what I need to do...........I have an '82 K-10 w/delay for parts. :laugh:
  5. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    It Is Plug and Play if you have the controller and switch. I need to do this upgrade real soon and have researched it a lil'. Good luck
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  7. dyeager535
    26,982
    191
    Plug and play as long as you are dealing with the same vintage of truck. The later switch ('80 or '81 until it went to the column) won't fit in the earlier dashes without hacking the gauge bezel up.
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    So I need to break out my....... :hack:
  9. dyeager535
    26,982
    191
    You can, as long as you don't care what it looks like. :)
    I can't recall if the metal needs cut as well, or just the plastic.
  10. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,727
    109
    earth
    On the column mount ones you unplug the harness under the little plate cover under dash and put the delay box in to the two ends. Install the wiper/turn signal lever with delay to the column and you are now ready to use delay wipers.
    I just did this on my 1987 using my 1989 as donor.
    Added:
    If you have delay and they stop working yes you can unplug box and have regular wipers just go past the delay part on turn/ wiper lever.
  11. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    Simply Plug n Play, I did this to my '79 K20 with parts from an '80 c10. With used parts this old its hit or miss on getting a working used box and switch.
  12. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    On eBay the switch arms sell for an average $24.00 if you watch or buy a parts truck for $500 get a motor trans and case ac and all the parts you need.
