Wiper issue
Discussion in 'The Garage' started by dave_90_blazer, Feb 3, 2006.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    OK, my 90 Blazer has intermitant/pulse wipers
    the wipers work fine with the switch, other then the fact that fast is not much different then slow, but hey
    here is the problem, the wipers operate on their own, seemingly at random, yet only for a single swipe at a time, and will still operate as needed via the switch
    so, anyone know what is up?
  2. goldwing2000
    goldwing2000 Guest
    Sounds like a possible short in the "mist" circuit of the switch. Either from a bad switch or just a sloppy combo stick.
  3. dave_90_blazer
    Jan 1, 2004
    688
    its a new stick, so you think it is the switch?
  4. goldwing2000
    goldwing2000 Guest
    Possibly. Since I can't see your truck from here (even though you're only a few miles away), I can't say for sure but it's a place to start. :)
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    10 bucks says it's the wiring in the steering column. The EXACT same thing happened on my 84 and I ended up having to replace the entire cruise/wiper harness that passes through the steering column.
  6. goldwing2000
    goldwing2000 Guest
    Isn't that harness part of the switch?
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yes it is part of the switch.
    Could be the pulse module too, what the harness plugs into towards the bottom of the column.
