Wiper Motor Removal??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaBnn3, Jan 2, 2005.
  1. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    I love my Suburban enough to try and fix it myself. But, I'm stuck on disconnecting the motor from the linkage through that little access hole on the driver's side. Not as shown in manual. Black nylon or plastic clip holds the motor to the linkage. Is there an easy way to disconnect the motor from the linkage. I'm stuck. Help!!!
  2. dmntd
    dmntd Registered Member
    Sep 20, 2004
    9
    On my 85k5 I was able to pull the motor away from the firewall to remove the nut that was holding it to the linkage.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    On my two '73's and my old '78 There's two little nuts on the top of that linkage, your need to only loosen them a tad, then the linkage practially falls off.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah well thats easy to get to on 80-older, on 81-up you gotta remove the cowl panel and such
    good luck
