wiper motor
Discussion in 'The Garage' started by mostwanted, Jul 14, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    My wipers do not always return to home when turned off and the intermittent and low doesn't work. Sometime it seems as if they have a hard time getting started in high. Would a new wiper motor solve this?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Sounds more like the controller. What year truck?
  3. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I'd probably say the module. But it could be the motor. Perhaps a bad ground , the motor grounds to the body, the module (in cab usally tied to the steering column, little black box with alum. fins on it) grounds in the cab. The wiring is a bit tricky, You can kinda of test the motor. Find the white wire going to pin C on the 3pin connector. With the key on, there should always be 12v present here. The module just plays games with grounding out other pins to get low speed and high speed. I don't remember which ones though. Sorry.
    Anyhow, I'd probably check the ground on the module in the cab, (black wire, pin d, on the side going out to the motor (not the side plugged into the switch) and see if that's good. Best thing to do though is goto the junkyard and pull a couple of modules, and swap them out.
    My best guess would be the module.
    Here's a post with the raw diagram. OEM colors in the corner. YOur motor is the same, except no integrated washer pump.
    http://coloradok5.com/forums/showthread.php?t=174785&highlight=wiper
  5. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    thanks 73k5blazer, I will troubleshoot this weekend. That is a very helpful post.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    mine did the same thing and it was the controller under the column.
