wiper motor?
Discussion in 'The Garage' started by gotmud77, Jan 19, 2004.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    can anybody tell me which wire is the hot wire at the switch? The wiring is not hooked up and i cant check it with a test light.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Is this for the 77?
  3. gotmud77
    Aug 4, 2003
    689
    bellefonte
    yes its for the 77. There are 3 wires on the motor and 2 wires on the pump. I have to run new wires out to the pump form the switch. The pailess kit only provides one power with for the wiper cuicuit so i am assumming that it works by applying ground to get the different functions. All i need to know is which one is the hot wire at the switch.
    Thanks,
  4. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    this is from memory but on my 74 the yellow or yellow with black stripe was ground. the dark blue was the squirter. now the other 2 wires together to 12 volts made it go slow.and just one of them makes it go fast in the same direction that is dose when it gose slow with the 2 wires. adding the second wire makes it slow down for some reason.
