Wiper motors don't return to the bottom
Discussion in 'The Garage' started by dremu, Jan 1, 2006.
  1. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    ...when I turn them off. Yes, I could just go buy a new motor ... but all my trucks seem to do it eventually, and at $60-$75 a pop, it adds up.
    Any of y'all cheapskate enough to try rebuilding these, or know if they fail this way frequently (or is it just my luck :mad: )?
    -- A
  2. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    clean the contacts??..
    There is a set of contacts under the cover for the washer pump,they must be clean..and the plastic wheel "cam" that runs the pump is what tells the "park switch" when to shut off the motor,so the blades stop where they are supposed too..
    Sometimes no amount of fudging with the wiper motor helps though,and installing a new or rebuilt(or known good used) one is the only way out..
    I learned to never to try "testing" a GM wiper motor OFF the truck!..it seemed like every time we tried "testing" one with a battery and jumper wires,something would screw up inside them,and they wouldn't "park" right,or not work on one speed or something--even though they worked fine when still attached in the truck to the stock switch and wiring when we tried them to make sure it was worth pulling..:screwy: haven't figured that out yet...must have them wired weird using ground for the switch,or something...:confused: :crazy:
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The switch gives the motor a ground. I had a motor with a slight short in the housing that kept it from working right. I fixed it easily enough with a little bend and electrical tape.
