WIPER PROBLEM
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Dec 22, 2000.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    I HAVE A PROBLEM. WHEN I TURN THE WIPER ON THE WINDSHIELD FLUID STARTS SPRAYING. I CHECKED ALL CONNECTIONS AND HAVE DETERMINED IT TO BE THE SIGNAL SWITCH. I PLAN ON REMOVING THE STEERING WHELL FOR A GRANT ANYWAY ANY TIPS ON WHAT TO DO? CHECK FOR? CAN I DO THIS WITHOUT TAKING THE STEERING WHEEL OFF? IT'S A TILT 4SPD
  2. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    What year is your truck?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You'll need two different pullers to get inside to where the switch is. First you need a steering wheel puller just to get the wheel off. Then you need the puller that lets you remove the lock plate behind the steering wheel. It's a real PITA, but once you have everything out of the way you can see the switch.
  4. KENNY
    Dec 7, 2000
    292
    nyc
    I READ THAT IN THE MANUAL THAT I HAVE. WAS HOPING THERE WAS AN EASIER WAY. THANKS FOR THE RESPONSE.
