Wiper Problems
Discussion in 'The Garage' started by airemdwn, Oct 21, 2006.
  1. airemdwn
    airemdwn 1/2 ton status
    Feb 22, 2006
    116
    Pennsylvania
    The windshield wipers on my 87 went from becomming "Intermittent Sometimes" to "Intermittent Never" and Now they are ON whenever you touch the switch. Which is better that Never On! However They dont turn off anymore either, you have to twist the wiper stalk backwards to turn them off and they dont return to rest, they just stop when to twist the stalk far enough.
    Am i better off looking at the switch, That pulse module thingy under the column or is the problem under the hood and thats why it doesnt return to rest?
    Any help is much appreciated.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    My burb does the EXACT same thing, i think its the dohicky under the column because the intermitant died on mine first then after i stored it for a year, they only work as you discribed.
    It must be a safty builtin so when the intermitant thingie goes you still have something.
    I have learned to live with it, but you could try replaceing the thingie and see, hey let me know :D
    dave
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    MOdule is a good place to start, as it's easiest to replace, and you can find them cheap in the yards. If you want a new one,they are like $50.
    It's located, usally, near the bottom of the column, a little rectangular black box, wire connectors on each end, and alum. fins on one side.
  5. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    I had this problem ( I think ). You turn wipers on for intermittent running and they run constantly as they would in low? You turn off wipers by twisting to mist, then holding until the arms are where you want to release the switch?? What I did was to pull the electrical connections, and clean w/sand paper. Single sheet thick fit in connections. Put a dab of dielectric grease on each connector and plugged back in. I found them working as they're supposed to afterwards. I did this on the wiper motor itself. Nothing else. Didn,t cost anything,but 5 minutes.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    my crew cab had the same issue, when you hit the switch they came on full. There was no delay to them. Once I replaced the module under the dash I had no problems with my wipers after that.
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    hummm :thinking:
    this is nice, i could never really be bothered befor since they stilll worked but this i like, i'll have to try that.
    thanks brother
