Wiper Troubles Driving Me Crazy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Aug 17, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    90 with intermittent wipers. Sometimes or just off/on while on intermittant midway across the windshield they stop for about a few seconds. Then they continue. Sometimes after that they will work fine or start to go non-intermittinantly. Its driving me up the wall, I cant figure it out to save my life. Any ideas?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    when it gives you problems, can you knock on the column and make it work right?
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Any work done on your column lately? (ie. turn signal canceling cam/switch, wiper washer switch, column bearings, etc...)
  4. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I had the same problem. Do a search for more info. Adjust the bolt that sticks out the top of the wiper motor. My problem went away when I did that.
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Ive tried fiddling/jiggling with the column and nothing happens. I put a new key cylinder in two years ago so that shouldnt be the problem. Ill give the bolt thing a try.
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Did you tighten or loosen up that bolt? Thanks
  7. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    On your wiper motor under the hood, is a plastic cover. Underneath this cover is a switch. The switch can be removed from the motor. The contacts get dirty and cause park problems. Clean the contacts (check with a multimeter if you got one) and it might solve your problem.
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
  9. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Not trying to hijack the post but can this be done on all years? I have the problem of the wipers not parking correctly, just stops 1/2 way up the windshield!
    Thanks, Shane
  10. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I loosened the bolt up a little. What the bolt does is put tension on the gear. Too much and the wipers will stop go stop go or just stop. Too little and the wipers won't stop.
