Wipers acting goofy...
Discussion in 'The Garage' started by 89GMCSuburban, Sep 26, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Myh intermittent has dissappeared. When I mist the wipers, they don't return to the normal spot, they stop when I let off of mist instead of returning automatically. When I put the wipers into int., they go to a low setting. If I put it back to off, they don't turn off. I have to click mist or go back into int. and back to off and, again, they shut off where they were. My high speed works fine. What the hell is going on?????
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    WOW mine do the exact same thing cept it doesn't rain much in NV so i haven't really looked into it much. I think it has something to do with the circuit card on the wiper motor. Let me know if ya get it to work right. /forums/images/graemlins/thumb.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like you need a motor..because they arent returning to the correct park position...i think..
  4. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    Mine do it too but Im just gonna deal with it until I get a new wiper motor. My wipers dont have the power to move once Im doing 50mph or so /forums/images/graemlins/crazy.gif When you figure it out tell us how ya fixed it /forums/images/graemlins/thumb.gif
  5. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    i dont know how much different the older motors are but the newer ones (mine is a 94) had a problem with the wire plug getting loose from the circuit board, they would work when they pleased and sometimes act like you described. some of those were actually recalled. i fixed mine, just pulled it out and resoddered the ends, i don't even know if the 83s use a circuit board but might be a simular contact problem.
  6. big blue beast
    big blue beast Registered Member
    Sep 27, 2003
    14
    Fairfax, VIRGINIA
    /forums/images/graemlins/thinking.gifMY 85 DOES THE SAME THING. I HAD IT CHECKED OUT AT A SHOP AND WAS TOLD THAT IT WAS THE WIPER MOTOR.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Mine do the same damned thing, tell me how you fix it, i dont really wanna swap my column out but i got a spare one, and then i also got a spare wiper motor so i might try that too. Id like to know how you fix it.
  8. krayzie
    krayzie Registered Member
    Sep 21, 2003
    18
    Flushing Michigan - Genesee County
    If your motor moves at all at the correct speed, then you need a new delay board... very common problem - even in older trucks. The board also controls park position so its a very good possibility that changing the board will solve all of your problems... Good tip - to keep the board good once replaced, run a small bead of black silicone in the groove where the cover bolts on... keeps moisture out - board lasts much much longer.
    Most shops will automatically diagnose the problem as a faulty motor. Truth is, wiper motors rarely go bad. This is where the money is for the reman companies. They get your core motor, slap a new board in, paint it, and make a damn fortune!
    I know some shops dont even know that delay boards can be replaced. AC-Delco is one of the only manufacturers (if not the ONLY manufacturer) that makes the boards available to the aftermarket. I ship Delco parts all over America every day, delay boards are in my top five most commonly delivered items! Good luck to ya!
  9. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Where would I find the delay board on the wiper motor?
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The dealer
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    it's the motor, my 79 did the same thing in a rain storm. my cousin was driving us up north(what we say in lower michigan) and the wiper's just stopped. then they came back just enough to go back out again.bought a new motor and it was fixed. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Thanks but I meant where on the wiper motor would I locate the circuit board?
  13. boggerless
    May 26, 2003
    22,728
    96
    didn't mean to waste your time bro,sorry. wiper motor's are cheap /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  14. Confedneck
    Nov 1, 2002
    5,236
    well the connector plugs into the circuit board...so you figure it out, pop the cover off and voila, its there..
  15. boggerless
    May 26, 2003
    22,728
    96
    oop's wrong reponse.still change the motor,word??? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  16. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Oh you didnt waste my time man, what I said wasnt directed to you. It was directed to Zcarzcar. I didnt ask my question good enough in the first place. Your probably right though, I might as well replace the whole motor.
  17. boggerless
    May 26, 2003
    22,728
    96
    that's cool man. i should have looked at who you res. to.sometimes it's easyier to replace stuff. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  18. boggerless
    May 26, 2003
    22,728
    96
    hey krazie, have you met ted nugent yet? my dad and uncle TED are volenter sheriff's in your hood.mostly carnaval's and such. yes the motor city mad man is a sheriff.he likes bronco's though. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  19. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Man that's exactly why I love this website... Thanks a lot! /forums/images/graemlins/thumb.gif
