Wipers tricky when turning off
Discussion in 'The Garage' started by eshorvath, Sep 9, 2005.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    When i turn on the wipers, everything is fine. But there is no speed difference with the different positions. Then when you turn the knob to off, they keep going.
    to get them to turn off, you have to twist past the off, and wait till the wiper is in the down position, then release.
    What causes this? Bad swithch? Relay? Anyone have this problem and fixed it?
    Thanksm,
    Eddie
  2. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    LMAO. same thing happens with mine except that the speed difference postions actually work. slow, fast and super fast. i learned how to deal with it, so i never tore into it. good luck :doah:
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    :haha:
    I now own two chevys and both wipers are tempermental. I think most of our trucks have wiper issues. For instance have you heard of ghost wipers yet? :haha: Sometimes you will hit a hard bump and the wipers turn on. My new burb doesn't stop squirting washer fluid until after my wipers are done, leaving fluid all over my windshield. Also the wiper motors are weak if you have ever used them in the snow or heavy mud they suck.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    My 89 does it too, ever since I bought it last year. But, the different speeds work fine ... it's just that I have to turn it back and hold it until the wipers are down, .. and let off. I have not bothered to see what it needs to correct it.. too low of a priority. I am curious if it's just the switch on the stem or not. :dunno:
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Don't know what to tell you. Mine are all weird too. The ones in my '78 1-ton will do a full wipe when I turn the truck on, then they stop. Other than that they work fine. The ones in my 78 1/2-ton stop in their tracks whenever you turn off the switch. You have to time it perfect to get them to stop at the bottom.
  6. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    Ghost wipers here. :dunno:
  7. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    "Pulse" wipers??
    My 79 C10 has the crappy "pulse delay" wipers,and they usually wont work on the "delay" setting,only hi and lo speed--now the wipers make one sweep every time I turn the ignition to start it up (well,almost every time)...I've been told the "Park" switch inside the wiper motor under the plastic cover near the winsheild washer pump has "points" in it that corrode and make them not shut off in the proper position,or do other goofy things!..have to look into it one of theese days-for now,as long as they still wipe when it rains,the truck has other things more important to fix than the wipers.. :crazy:
  8. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    It's probably the switch in the dash. Mine did the same thing, but when I replaced the switch, the problems went away. It's pretty easy to replace too. :laugh: I don't know why I put up with it for so long before I finally replaced it.
  9. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    What switch in the dash?
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Seems like everyone has this problem, but none of us has fixed it yet.
    :doah: :haha: :doah: :haha: :doah: :haha:
  11. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i rebuilt my whole system solder n all- they work pretty well now but never found exactly what was the problem. now if i would just buy some wipers they might work good :D
  12. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    I fixed mine, it's called unplugging the wiper motor until you need em. :D
  13. hero
    Oct 21, 2002
    65
    Omaha, NE
  14. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Well, I had the problem and I fixed it...
    It was a combo of a bad regulator module (under the dash with a heat sync on it), and a bad wiper motor. This is assuming that the switch still goes into the positions correctly. I was having this problem until I got fed up with it and decided to change it. I would have to hold the wiper in the mist setting, and release it when the wipers were down in the retracted position to make it stop. And I had a fast setting, a real fast setting that slowly went to fast, and an off (sort of)
    After the module replacement, it solved the speeed issues, but still wouldnt stop.
    The new wiper motor (sealed kind, not the newer style with removable external regulator) fixed the start/stop issues.
