Wire Brush for a 4" Angle grinder?!
Discussion in 'The Garage' started by socal chevy, Jan 24, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I have looked EVERYWHERE and I cant freaking find one! The only wire brushes I have seen are for a drill-motor. Where can I find one that will attach and work on my angle grinder?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    why? drill one works great, faster than that and you will start removing metal and ruining the wire wheel in no time. Get a flapper wheel, its meant to remove small amounts of material, or with heavier grits do things like clean up welds(remove more material).
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    yea flap disk's work great
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I've seen them at most places that sell welding supplies. Is there a farm supply place around there (IFA, Fleetfarm, Farm and Fleet, Tractor Supply)?
    I use both the drill mounted and the wire cup on my grinder. Definately faster and easier to control on the grinder for big areas.
  5. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
  6. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    they make them...
    I've bought them at Lowe's and Home Depot--and like the other post said,welding supply stores(they charge more there)--in a pinch I took the gaurd off my 4-1/2 inch grinder and used one designed for a bench grinder with a 1/2 inch hole,had to file it out a hair,as mine had a 14mm spindle(HAD,I need a new grinder now,finally killed it after 5 years of chopping rusty sheet metal and bolts off!--I think I dropped it too many times more than I wore it out!!).
    .I think the next one I get at the "bargain" store for 15 bucks will be the one with a wire brush and a few discs and other goodies in a blister pack( and hopefully it wont have that 14mm wierdo spindle thread--only Bosch grinders used that thread,a pain to find the wire brush for it----the last one I got there was only 9 bucks!!,and it lasted 5 years--for the amount I use one,I cant see buying a 50-75 dollar mikita or dewalt one,if I used it daily I would,but I dont...:crazy: :crazy:
  7. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    I got my 4" one at Sears. I had to get an adaptor that they also sell to fit it on my Makita grinder. This thing puts the drill mounted ones to shame! Works great for removing paint from heavy metal parts and cleaning off rust. WEAR GOGGLES!!!! :grin:
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I get my tight knot wire wheel for the angle grinder at the Napa near my work. It is in an industrial district so they carry some industrial stuff like welding supplies and grinding wheels, etc.
    The knot wire wheels on a grinder are WICKED!!! :D
    Harley
  9. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I prefer a faceshield. These things will stick in your face when they come flying out.
  10. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    another vote for the flapper disc. I had never had one until two weeks ago and damn is it handy. I was stripping all the brackets and stuff off a toy axle housing. Ground all the big stuff off and then cleaned everything up with the flapper. Great of taking off a real small amount of material before priming bare metal. After using one, dont see how I ever got by without it. lol!
    j
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The drill motor brushes are Dangerous on a grinder. They are not built or balanced to handle the rpm's of a grinder. I tried that once and got a chest full of wire bristles!! A good hardware store should carry grinder brushes-Makita makes some good ones. I used one of their cup brushes to clean about 300 sqft of concrete floor and it is still in good shape.
  12. Ruthven13
    Mar 10, 2003
    664
    Fair Verona
    Yup, even better! And I try to not have my face in the same plane as the wheel as well...
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    What he said. Safety Glasses under the face shield pleaz. Welder leathers and leather gloves are also a good idea. Don't screw around with those wire brushes, they'll git ya. BT (stuck in me part), DT (pulling them back out)
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A have a fine wire brush for my grinder. I use it to clean differential covers, waterneck outlet on my manifold, the "c" things on my D44 when I did new ball joints, ets... I use mine for a lot of things that would be a real pain with a drill. A fine grit flap disk can really make metal look good, almost like it has been polished.
  15. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    anyone have a pick of a flap disc, im confused as too what it looks like....
    I got a 4" wire brush, and have cleaned up about 1/2 of the 14b so far. Its hard to reach the small nooks, and crevises. Any hint to get into the tight stops??
  16. divorced
    Jul 20, 2004
    5,115
  17. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I use both wire and flap disks. It depends on what I am doing.
    The wire knot style are the ones to get. The others throw out wire at you and become very unbalanced. My last wire knot wheel lasted through 8 bumpers, 4 axles, 3 cages, 2 pairs of sliders, set of nerf bars and some other little stuff I have done. I love the things
  18. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    Mcmaster carr catalog and if ordered in the am will be at your door that evening or the next morning use them at work on a 4" grinder cleaning rust and fiberglass off of molds. Like said use the twisted wire ones those like on a die grinder kill you throwing niddles at you that you pick out of your cloths and self for awhile.
