Wire colors for bypassing the window up/down safety switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Blazin, Jun 18, 2002.
  1. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Not in the tech section, and I've read it here in the past. Can anyone tell me which wires by color code I need to jumper in order to bypass the rear window up/down safety switch? I know where the harness is, and have found the plug...figured I'd put in a temporary jumper until I get time to replace the switch. /forums/images/icons/confused.gif
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I'm more familar with the older style wiring, but most will cross over here. Brown=down Blue=Up Red=constat hot for key operated switch. The later models like yours have a Black wire going to the gate too. I think thats a ground, my '82 doesn't have that. Take off the access panel and stick your hand up by the latch on the driver's side. There is a plug going in there that hooks up to the safety switch. Simply unplug that and stick a jumper in that plug and things will work just fine.
