Wire routing?
Discussion in 'The Garage' started by jfaulk, Mar 8, 2007.
  1. jfaulk
    jfaulk Registered Member
    Dec 3, 2006
    60
    NC
    I am running a wire from my dash down to the trans pan and I am also running a new speedo cable. Think it would be alright to run the wire and the cable through the same hole together? It makes sense to me because they are basically going to the same place. Anything I'm overlooking? Thanks
  2. dyeager535
    26,979
    Should have no problem running them through the same grommet.
    IIRC, the speedo cable grommet is pretty soft, run the wire before putting connectors on the end and it should fit through pretty easily, shouldn't need to make any mods.
  3. jfaulk
    Dec 3, 2006
    60
    NC
    Thanks. Just wanted to make sure there wasn't something glaringly obvious that I was overlooking.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Just my $0.02 and maybe being overly cautious here: I would run the wire through a different grommet hole if possible, depending on the size of the wire. The speedo cable is fairly rigid. With the movement and vibration, you may have problems down the road.
    I personally don't like to share space with electical wires and cables of any type.
