Wire Routing
Discussion in 'Audio' started by daleearnhardt01, May 21, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Just got my new receiver and sirius system. Looks like Ill have to put the antenna on the roof of the cab. How should I run the two thin wires down into the truck? I dont really want to put them thru the top due to pinching them. Maybe somehow thru the slider windows on the topper?
  2. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    from the looks of your avitar, you have a lighted visor. where are the wires for it going thru?
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Hey that might be a possibility!
  4. Rebel-Rider
    Rebel-Rider 1/2 ton status
    Sep 30, 2001
    134
    North Dakota
    i ran mine on the inside of the window molding down and under the metal then through the door into the cab i had one exposed spot that i covered with white electrical tape /forums/images/graemlins/thumb.gif
  5. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    I know it's probably to late now but they make a glass antenna for those. I believe it's a pass through type like the glass mount cell phone antennas. You have an inside part and the outside piece that stick to the glass and the signal passes through the glass. You could put one of those on your sliders and keep all of the wiring inside. If I remember right, you got it from Crutchfield. They have a good return/exchange policy. You could check into it if your interested.
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Ill check on that.
