wire that goes into the block above the starter
Discussion in 'The Garage' started by adamforsythe, Mar 21, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What is the deal with that wire that goes into the block above the starter?
    What is it and what does it do?
    Adam
  2. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    knock sensor?
  3. dyeager535
    26,975
    I concur, knock sensor more than likely. (if factory)
    Does/did the truck have ESC or CCC?
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What is a ESC or CCC? This is a 1985 K5 Blazer with a new 5.7L create engine. It is carbed.
    Adam
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    e= electronic
    s= spark
    c= control
    and if you have a 2 wire blue plug on top of your carb then you have the electronic cab for fuel control .
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    also known as ESt and an 85 would have this
    it is electronic spark timing
    ESC is 99% the same deal
  7. dyeager535
    26,975
    And I may at least a partial mistake in my previous post. CCC on trucks (Computer Command Control) from what we've seen here so far, did not use a knock sensor.
    The original factory truck engine I'd guarantee was a 305/5L IF it has ESC. ESC was used due to the relatively high compression of the 305 with the crappy cylinder heads of the time. Saved the engine in case there were problems, the ESC (via the signal from the knock sensor) would retard timing.
    The distributor is different than "standard" HEI, and there will be a small computer box behind and above your glovebox.
