Wireless winch controler on the CHEAP.
Discussion in 'The Garage' started by darkshadow, Jan 30, 2006.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    Have i wire less winch and more!!!!!!!
    with 4 channels, you can power multiple accessories, used 4 internal 15 amp relays.
    great for anything, i am going to hook it to my winch in/out:woot::woot:, and locks for remote locking/unlocking.:bow::bow:
    came with wireing harnesses remote, with extendable anntenna and a velcro pad to mount it.
    I am so stoked about this, i can get more so if any one wants one PM me and ill mail it out!!!
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Uhh....so what the price? Just curious.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    uh cheap!:D j/k ya man. look good, hope it works out good!
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    it should it says, max range 185 ft, witch is triple the range of the kit sold just for your winch.
    and the whole thing was about 50 bucks! way cheaper then the winch kit!!!!!!!
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    The only caution I'd make is to figure out what frequencies it uses to broadcast to the receiver (and is it smart enough to only accept signals from YOUR remote?)
    It could be a disaster if a CB or other wireless device suddenly started signaling your winch to pull (or release) when you were doing an extraction in a precarious spot. This would be especially important if you start setting up all your buddies with the same type of remotes and you are all out on a trail ride together......screwing up each others' winches for the rest of the day!!! :eek1:
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i have thought of that.
    since i will also use the remote, to remote lock/unlock my truck, i am going to have a arming switch on my incab winch controles, so that way it will only work when i have acavated it.:waytogo:
    i am also sure that they work on a range of frequanceies alwell, as there is a number listing on the box, i will test this out also when i go back and get more. :D
    i would suspect that it would work better then ones sold for winches only, and have a range of frequincys
  7. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    You may need some external relays. 15 amps is not much when using a winch. Use the trigger from the module on some bosch 30 amp relays with some heavy guage wire.
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    I am not worryed it would just be for signal wires, any thing that has a switch has a relay in my truck.
    I got it hooked up temporaraly to test it out, it works like an inline switch, each channel independantly powered and switched by there oen relay.
    I hooed a channel up to a floresent light stuck it on my dash, and went for a walk to the end of my street, a good 150 feet away and clicked the light on and off no proplem!!!, even with the anntenna down.
    you would be able to walk to the end of ANY winch line and power it in NO PROBLEM.
    as soon as I build my over head console it will have a permenit home :saweet:
