WIRERING
Discussion in 'The Garage' started by 78GMC1/2TON4x4, Jun 26, 2004.
  1. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    can a 78 blazer wirering be put in a 85 blazer with no wirering? thanks
    /forums/images/graemlins/k5.gif
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Some of it will work but some of it won't. In 85 the distributor had a minimal amount of computer control like knock sensors and stuff like that but the old harness won't have those hookups. Other things that might be different could be steering column stuff. Delay wipers and cruise and the like. For all the headache you'd probably be better off going with a harness from the correct year donor. Some of it should work though.
  3. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Change the Dist. to a standard HEI. Eliminate the limited 'puter. The feed back carb will still function fine.
