Wires Needed
Discussion in '1982-Present GM Diesel' started by cegusman, Sep 29, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I want to remove my factory wire harness, and run the minimum wires to have the 6.2 running. What needs power to get the 6.2 running?
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I assume you replaced your gasser with a 6.2 ? Use the hot wire off the distributer to use on your injecter pump .
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    like he said injector pump hot with ignition on off with ignition off
    next cold start advance can be hooked up on a seperat switch as can glow plugs then just power to the starter and cab
    good idea tohave oil and water temps though but both of those ya can do manuel
    Im sure im forgeting something to but for now thats all can think of
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Nope, it came factory with diesel. I am about to pull the tub and go all tube, The factory wire harness is slowly dying on me(Shorts, very britle, and has been hacked by previous owners).
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    [/ QUOTE ] What does that do, Where is that located, Is it really needed? I am down in Houston, Tx it does not get too cold down here.
  6. 6.2 man
    636
    Curtis , WA
    The cold start is on the right engine head . I would run the same wire to it . The other wire that comes off it goes to the injecter pump and high idle . This makes the diesel easier to start when cold
